12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Sheets in families?
7 Posts No Rating |
In Revit Building 9: Is there a way to have sheets in a family file? There is a sheets drop down in the browser... so can you define sheets? -Thankers
7 Posts No Rating |
*bump
No...sheets are only available in a project. Why would you want to do something like this?
46 Posts No Rating |
Iwould like to do it (unless there is a better way) to print out shop drawings of idividual pieces I have created
Is there any reason you couldn't load the family into a new project and print from there?
What I have found to work is create a seperate titleblock family as a GENERIC ANNOTATION. You can apply lables and what not to it then load it into you 3d component family. It will come in as a symbol so just pick the symbol command and place it. Otherwise if this is too much of a hassel I'll just export it to CAD and finish it in there. HTH
Reordering Sheets |
Thu, Nov 1, 2018 at 2:09:29 PM
Sheet Number Already in Use...I have ghost sheets. |
Tue, Nov 21, 2017 at 8:47:10 PM
In place families above the view range are still appearing |
Tue, Dec 23, 2014 at 9:17:05 AM
Linked Revit Model Sheets |
Fri, Apr 5, 2013 at 12:04:28 PM
CONTROLLING THE ORDER IN WHICH SHEETS ARE PRINTED |
Tue, Aug 5, 2008 at 1:18:31 PM
