12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> exporing detail view, drafting views, + legend views to other revit projects 9.1
4 Posts No Rating |
I am currently in Revit 9.1 and have two very similar projects. One is completed for construction w/ all the details that I need. The second project is completed excpet for the details. I want to copy/paste my details from the finished project to the unfinished project. It seems as though all details components should be able to copy easily but they are not. Also I understand that when you cut a detail view and draft over it there are 3d componenets that are attached to it which makes it difficult to export to anouther project. Is there any way that I can just save the 2D and export it. There is a save view and save as 2D option but they do not seem to work. Has anyone successfully been able to complete this process? Thanks.
Try the File>Insert from File>Views and choose the 'master' project that contains the 2D views you wish to transfer. It will only work for drafting views and schedules though. Most details I do are '2D embelleshments' that are placed on top of a live section cut of the model. These elements can be grouped (version 9.1) and saved to disk as a group. (not sure what happens in 2008 with this method) These 2D groups can then be loaded into your project and placed over the model.
Tom www.reviteer.com http://twitter.com/Reviteer |
Flagging new Drafting Views - How to reference a drafting view detail? |
Wed, Aug 1, 2007 at 10:26:29 AM
Trouble copying detail items from Section View to Drafting View |
Mon, Aug 19, 2013 at 1:08:05 PM
Converting Model Views to Drafting Views |
Fri, May 13, 2016 at 2:13:29 PM
Head, Jamb, Sill Details - Detail vs. Drafting Views |
Wed, Jul 15, 2009 at 3:20:17 PM
Drafting views as x-ref/blocks |
Wed, Oct 22, 2008 at 11:32:29 PM
