Forums >> Revit Building >> Technical Support >> Stairs text
Thu, May 3, 2007 at 5:11:26 AM | Stairs text
Safety
1 Stars: 1 Votes
Can someone tell me if it is possible to make the stairs "Up" & "Down" text transparent??
If so how do I set it. "I'am using revit 9.1"
Thu, May 3, 2007 at 9:17:33 AM | Stairs text
rkitect
rkitect Avatar
4 Stars: 29 Votes
Do you want it transparent or to disappear?  I don't think there is a way to change the opacity so that it is like a ghost type.  You can turn it off by using the View Graphics dialogue under Stairs.
If you need to make it so you can see the stair treads, you can always just drag the 'Up' and 'Down' text out of the way.
Thu, May 3, 2007 at 9:44:26 AM | Stairs text
Safety
1 Stars: 1 Votes
I want the text to go transparent as you can set your normal text to transparent or opaque!
But it doesnt seem like its possible to add the parameter to the stairs properties as it is with the text!
The thing that bothers me is the fact that when you use a smaller scale the text size becomes bigger, and i was wondering if I could make it transparent so I could still see the treads! Will switch it off and put in normal text where I need it.
THANKS
Text except up/dn in stairs???
Mon, Feb 16, 2009 at 12:50:14 PM
stairs up & down text cannot be moved
Thu, May 8, 2008 at 7:26:11 AM
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:15 PM
Wrapping stairs
Thu, Aug 12, 2010 at 5:27:02 PM
Handrails at Curved Stairs
Mon, Sep 1, 2008 at 1:43:04 PM
Page generation time: 0.2178
