Forums >> Revit Building >> Technical Support >> Glitch with several layers of glass?
Wed, May 2, 2007 at 9:55:08 PM | Glitch with several layers of glass?
lah326
I was curious iof there is a fault with the render engine that it has a hard time going thru multiple layers of glass.  I have a glass framed curtain wall building with some interior walls that are all glass. (ex terior wall is actually two layers)  Does revit not like to render thru multiple layers of glass b/c the furthers layer of glass (the back one if looking thru three panes) is rendering black.  It isnt my material b/c if i reverse angles, they render clear.  Any suggestions or input?
Thu, May 3, 2007 at 1:29:00 PM | Glitch with several layers of glass?
archdan
3.5 Stars: 2 Votes
When setting up your rendering scene settings, you need change the value for transparency bounces.  This number (by default - 3) has to do with how many layers of transparent objects light will penetrate through. When the maximum is reached the output is black.  Typically, I set it to be one layer higher then what is shown (i.e. for 4 planes I set it to 5).
Rendering glass with pattern 2009
Mon, Oct 13, 2008 at 3:27:21 PM
Multi-Layered Sliding Curtain Wall With Glass + Fabric Curtains
Mon, Jan 4, 2016 at 9:41:21 AM
Rendering Wood Floors + Appliances
Sun, Dec 16, 2012 at 7:22:55 PM
Revit 2013 Stair Glitch
Mon, Dec 17, 2012 at 11:16:11 AM
Transparency of glass windows in 3d views
Wed, Aug 5, 2009 at 10:43:37 AM
Page generation time: 0.0950
