Forums >> Revit Building >> Technical Support >> Filled Region Upgrade Problem
Wed, May 2, 2007 at 8:27:20 PM | Filled Region Upgrade Problem
anthonyforlong
Hi All,
When I upgrade an old project (From Revit Structure4 - Revit Structure 200Shadey any detail components that have a black solid filled region turn to white?  The detail component works fine if I insert it into a new 2008 project, I've tried removing the family from upgraded project and re-loading the component, however I still have the same result, any ideas or solutions would be greatly appreciated.
I've also noticed that this seems to effect any detail components that have a filled region, the hatch pattern used by the filled region doesn’t show up!
RegardsAnthony
Problem with filled region
Mon, Apr 4, 2016 at 11:26:17 AM
Masking Region Fill Region Problem
Mon, Mar 10, 2008 at 11:06:24 AM
filled region pattern color changes when drawing scale changes
Thu, Apr 14, 2016 at 7:32:06 AM
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:33 PM
Deleting Types From Filled Region Families
Tue, Sep 9, 2008 at 6:56:41 PM
Page generation time: 2.2761
