26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Reading "Points File" to build a toposurface
Attached is a points file obtained from a landsurveyor (PP25.TAC) its really just a txt file with XYZ tag values I have edited this file in Excel and cut & paste only the XYZ values into columns. Then Save As (Points File_0247.csv) this is then the file I'm trying REVIT to read, building a site from a points file. I have no joy, can anyone help, PLEASE!!!
I don't see how you can do this in Revit but I know you can in AutoCAD if you have the right lisp routine. Once the poits are set in a 3d drawing, you can easily import into REVIT.
WWHub, Do you know where I can find that LISP routine I also use AutoCAD. I have also heard about creating a Digital Terrain Model (DTM) in AutoCAD using a script file to place the coordinates from the points file. But I'm out of time. Any HELP will do.
Sorry - At one time I could have written it but not anymore. Your surveyor should be able to furnish you a dwg file with the points in it. The surveyor or a civil engineer may have a lisp routine to convert the file.
Toposurface by points |
Fri, Oct 8, 2010 at 5:50:31 PM
Toposurface, Shared Coordinates, and Contour Labels - Need Help Fixing |
Wed, Aug 31, 2011 at 5:29:12 PM
Best way to build stuff (not "buildings")? [ 1 2 ] |
Sun, Nov 2, 2008 at 4:42:31 PM
25
Possible to place contour lines to toposurface instead of points? |
Fri, Jun 1, 2018 at 2:57:52 PM
Using Survey Data to create a toposurface |
Mon, Oct 4, 2010 at 2:23:28 PM
