Forums >> Revit Building >> Technical Support >> Door Lining Depth
Wed, May 2, 2007 at 6:45:14 AM | Door Lining Depth
Sparky
5 Stars: 3 Votes
The Question is this.
Has anyone come up with a way/workaround to schedule a door lining depth? (the door lining will always be equal to the overall wall thickness it is placed in)
At the moment im doing it via a text parameter and its doing my head in.
Id even apreciate a reply that says "YOU CANT DO THAT" so i can get on with my life!!!
Thanks all
DAR
Edited on: Wed, May 2, 2007 at 6:46:08 AM
Wed, May 2, 2007 at 8:00:56 AM | Door Lining Depth
framerman
4 Stars: 13 Votes
Well, I might get proven wrong, but I don't think you can and this is why. There might be an intelligent workaround that I haven't heard of.
When you make your family, you attach your jambs to the face of the wall. The thickness changes, then so does the jambs. So the only way to do this would be a parameter of the wall thickness and you get an error when you try to constrain the wall with a dimension.
The only thing I could think of, but would be a complete PITA would be to reference plane the jambs, attach one plane to the wall and another would be unlocked, but dimensioned. You would then have to set the thickness manually. Not a very good solution, but it helps with scheduling. On a large commercial, forget it.
Edited on: Wed, May 2, 2007 at 8:02:54 AM
Wed, May 2, 2007 at 9:53:12 AM | Door Lining Depth
TomDorner
4.5 Stars: 25 Votes
framerman is correct in that it can't be done.
Collectively Revit users have been asking to be able to read other parameters such as wall thickness for years.  It seems though that our requests simply fall on deaf ears at Autodesk.  All I can suggest is that you file a support request with Autodesk and state your problem, what it is costing yu in terms of time and errors and then propose a solution of being able to read the wall thickness into a formula.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Thu, May 3, 2007 at 2:39:56 AM | Door Lining Depth
Sparky
5 Stars: 3 Votes
All i want them to add is a "read only parameter" - a parameter you can attach to whatever you like and pull info from it. That would be usefull in countless situations.
Seems like im stuck with my text
Thx guys, ill send autodesk a report then.
DAR
Door lining depths in schedules
Thu, Apr 5, 2007 at 5:32:01 AM
Digital Red Lining
Mon, Jan 6, 2014 at 6:23:46 PM
Cant find ductwork lining settings and fitting settings.
Tue, Apr 7, 2009 at 10:44:56 AM
Control Position of Door Frame/Panel in Wall Thicker Than Door Frame
Thu, May 6, 2010 at 7:29:41 AM
Advice on wall linings
Fri, Oct 27, 2017 at 5:19:12 AM
Page generation time: 0.4376
