Forums >> Revit Building >> Technical Support >> building a physical model from a revit file
Tue, May 1, 2007 at 11:52:15 AM | building a physical model from a revit file
pepsiqueen
pepsiqueen Avatar
in our office, we use elevations, sections, plans etc. printed from revit to adhere to chipboard for quick small physical models. I am wondering how many others mat do this, and if anyone has come up with a good solution for complex angled roofs. right now i have to sort of guess on the roofs; it would be great if revit had a command wherre it could directly print 'model pieces' of different elements. i.e. a sloped roof printed parallel to the surface so you could just adhere the print out (w/shingle/standing seam texture) right to the chipboard for the physical model.
any one have any suggestions??
I'd rather be riding at whistler. or highland. thats good too.
Tue, May 1, 2007 at 11:56:17 AM | building a physical model from a revit file
TomDorner
4.5 Stars: 25 Votes
Have you looked into 3D printing?
http://www.zcorp.com/
Tom
www.reviteer.com   http://twitter.com/Reviteer
Tue, May 1, 2007 at 12:05:38 PM | building a physical model from a revit file
pepsiqueen
pepsiqueen Avatar
ive looked into that but the models we build need to be adjustable; rip off a wing and redo it. also they tend to be last minute.
Wed, May 9, 2007 at 1:27:30 PM | building a physical model from a revit file
inverted
if i understand your question right, i think you can set your workplane as the surface of whatever angled part of your roof you want printed, then go to view/orient/by plane...
this will give you a perpendicular view to the roof angle you want printed. HTH
Wed, May 9, 2007 at 9:31:57 PM | building a physical model from a revit file
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Two options, use a 3D view orientated to the plane and isolate the element and print it.
OR use detail sections cut parallel to the face of the element.
Regards,
Chris.
whole project: walls, floors and roofs for laser cutting and building a physical
Tue, Jun 18, 2013 at 7:43:15 AM
physical to analytical model Conversion Mechanism and Etabs
Sun, Apr 5, 2009 at 8:49:34 AM
Physical Camera
Sat, Jul 10, 2010 at 5:22:35 PM
EXCISTING BUILDING FILE AND NEW BUILDING FILE, HOW TO MERGE P.E. ELEVATIONS?
Tue, Apr 29, 2008 at 7:54:05 AM
Created channel column shows off its structural axis (physical appart blue line)
Thu, Jun 27, 2013 at 5:46:12 AM
Page generation time: 2.7524
