12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Keybord shortcuts for individual user logon?
83 Posts No Rating |
Hi 2 questions about shortcuts: 1. As the text file for them resides in C:\Program Files\Autodesk Revit Structure 4\Program, does that mean if someone logs on & uses Revit on my machine they use my shortcuts? If true, is there a work-a-round? Wouldn't it have been useful to put them in the user sections of Document 7 Settings? 2. I use Textpad as my text editor. unfortunately it does something to the text file& when reloaded none of the shortcuts work. Any ideas why? Thanks in advance. Dave F.
1. Yes it is true that Revit does not have user profiles. This means that you have to use login scripts to copy your keyboard shortcut file around from a central location. Same applies to revit.ini file. Revit need to 'grow up' a bit in this area if it wants mass adoption in larger firms. 2. I use notepad which is the safest bet. Be sure that what ever text editor you are using saves in pure ASCII no formatting.
Keyboard Shortcuts Fails to Save or Import |
Mon, Jun 27, 2011 at 6:25:50 AM
Some Keyboard shortcuts not working? |
Tue, May 5, 2009 at 2:52:55 PM
Keyboard shortcuts |
Thu, Jul 3, 2008 at 11:14:44 AM
Revit Shortcut to enter dimension |
Wed, Apr 2, 2014 at 10:31:50 AM
Turn on/off inserted DWG quickly |
Tue, Oct 8, 2019 at 9:14:02 AM
