14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Emailing Revit Files?
I did a search for "emailing Revit" but came up empty-handed.... How can I email a Revit drawing to my other office? I tried it once; the file for a simple home was 15 MB and it took forever even on DSL. I tried to "zip" it but it only made a small difference. Any suggestions? Or should I head over to the post office?
John Acosta ARA, Architect Mountain Architecture, Big Bear Lake CA |
Best bet would be to make sure you purge unused before saving. 15 mb's is a small file though. they can get down to 1 or 2 mb's but that's usually just a template file. as soon as you start adding families and such. I don't know very much about worksets and sharing but you might want to look into that to see if you can implement it to your advantage.
For sending Revit files around it makes much more sense to use something like buzzsaw or an FTP. These are standard practice when sending anything larger than 10MB. If you can't arrange that, then a CD in the mail is your next best thing. A revit file is already compressed so zipping it doesn't do much at all.
Regards,
Chris.
try useing usendit.com, its free and you can email files up to 2GB. ive used it before and it works
----------------------------------- My Futurama Fan Fiction 'Hammer087' - http://futurama-madhouse.com.ar/fanfic/indexh.shtml#hammer087 |
I use a free program called Pando available at http://www.pando.com/ to send up to 1 GB files.
emailing a revit file in pdf form? |
Wed, Jul 29, 2009 at 12:16:11 PM
Revit 2013 |
Fri, Jul 25, 2014 at 7:23:09 AM
Converting Revit files to AutoCAD files |
Wed, Sep 15, 2010 at 2:09:17 PM
HOW TO IMPORT 3DS files and DXF files into REVIT 2011? |
Sun, Nov 7, 2010 at 6:21:00 PM
Newbie trying to understand central files vs. import revit files |
Tue, May 5, 2009 at 6:55:03 AM
