Forums >> General Discussion >> Wishlist >> Text Along a arc
Mon, Apr 30, 2007 at 2:17:57 PM | Text Along a arc
mjbednarczyk
mjbednarczyk Avatar
3 Stars: 2 Votes
I am trying to create a professional engineer seal which has text that is placed along the circle. I can not find a text command that does this in Revit. If I did not have and AutoCAD file to work with I would find this very difficult  to construct in Revit. I know this is not a widely used command but on occasion it would be useful and I would not have to rely on AUtoCAD to construct this.
Are there any other suggestions in order to construct this?
Mon, Apr 30, 2007 at 9:56:31 PM | Text Along a arc
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Are you talking about model text or drafting text?
Unfortunately this is not possible and you would need to do each letter separately in order to rotate each letter the different amount.
Regards,
Chris.
Mon, Apr 30, 2007 at 11:05:42 PM | Text Along a arc
katia
Or you can insert one letter , do an Array along the arc and change the arrayed letters to form the final text.
Tue, May 1, 2007 at 7:17:24 AM | Text Along a arc
mjbednarczyk
mjbednarczyk Avatar
3 Stars: 2 Votes
Thanx for the reply. You confirm what I suspected.
Wed, Aug 3, 2011 at 6:39:26 PM | Text Along a arc
inspektorgadget
radial array of text worked... but what a PITA.  fix this please!
ARC LEADER NO TEXT
Thu, May 2, 2013 at 10:36:04 AM
Divide arc by length
Fri, Sep 7, 2007 at 6:17:46 PM
Arc Walls with curved top?
Thu, Aug 7, 2008 at 2:04:21 PM
Parametric Arc Sweeps - How to Bypass the Concentric Arc????
Mon, Jan 14, 2013 at 9:00:26 PM
MOVING DIMENSION TEXT
Tue, May 1, 2007 at 4:05:42 AM
Page generation time: 0.2028
