26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Wrapping sweeps at wall ends & corners? Any suggestions on how to?
When I add sweep profiles to my walls to represent the base, wainscot, or crown mold I find, so far, no way to have them wrap around corners or ends of walls. Am I missing something? Thanks in advance for any help. Would you mind emailing if you have a suggestion?
odomarchitects@sbcglobal.net
5 Posts No Rating |
as long as you add a sweep to each individual wall face they should automatically join using a mitered edge or whatever you select for the join
18 Posts No Rating |
as far as a situation that is only a wall end, i dont think that you can wrap sweeps around them. if its essential to show a sweep in this location, try fooling the system with sweep returns. i havent done it myself, but you could always create a family peice that would fit on the corner and "complete" the geometry of the sweep.
Wall sweeps wrapping at ends? |
Thu, Jan 15, 2015 at 11:34:53 AM
wall wrapping problems |
Wed, Mar 4, 2015 at 9:59:02 AM
Wrapping Sweeps for Crown Mould |
Fri, Feb 10, 2012 at 4:00:50 PM
Wall joins (or wall corners) |
Sun, Nov 18, 2012 at 10:40:59 PM
Gyp. automatically wrapping entire concrete column |
Wed, Mar 4, 2009 at 2:32:16 PM
