19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Applying a Family Parameter
2 Posts No Rating |
I have a question on a fairly sophisticated family that I've simplified to what you see in the attached RFA (this is a Revit 2008 question). The issue is that I have two extrusions (extrusion, hollow extrusion) which are nested into my parent family (Problem Family). Revit has the capability to have families themselves as parameters - so if I want, I should be able to swap out hollow extrusion for extrusion and vice versa. So - I've created a parameter called Extrusion and Type and then four types. I've brought in my extrusion and then placed, aligned and locked it to the height ref. plane so that it will move accordingly as the user selects the various types. 1'H Extrusion should move the extrusion family to 1' off the ground. 1' H Hollow Extrusion should have my hollow extrusion family 1' off the ground. But that's my problem - when I change my parameter (Extrusion Type) to Hollow Extrusion - it breaks. However there is no problem in adjusting the height - if I move to 5' H Extrusion, everything works fine - it's just switching from one rfa to another that seems to be creating a major issue.I've seen the Revit Help document on this: Creating and Applying a Family Type ParameterNo dice. Anyone have a clue how I can get this to work and what I'm doing wrong?
Looks like you didn't add the Lable to the Hollow Extrusion. Try it now..
----------------------------------- BallewDesigns.com |
2 Posts No Rating |
I don't think that's the problem...if you go to Family Types, the parameter "Extrusion Type" has two families as options - that includes the Hollow Extrusion. Also, if you lock yours extrusions so that they will move along with the height reference plane you will see that it breaks - which is the issue I'm dealing with.
I looked at it again and the only thing I could find is the Hollow extrusion didn't have the height locked to the height parameter in the family. See if it works now..
Family material parameters duplicating issue |
Tue, Mar 11, 2014 at 2:27:48 AM
Massing - Applying Materials to Imported Geometry from Rhino-HELP! |
Sat, Dec 10, 2011 at 6:30:09 AM
Add Family name to a shared parameter |
Tue, Jun 23, 2015 at 8:50:48 AM
<Family Type> parameter can't be controlled by formula. What else can we do? [ 1 2 ] |
Tue, Aug 27, 2013 at 3:53:53 AM
29
Family with coordinate parameter? - Revit 2010 |
Wed, May 12, 2010 at 3:45:58 AM
11
