Forums >> Revit Building >> Technical Support >> Text Line Weight
Fri, Apr 27, 2007 at 7:47:58 AM | Text Line Weight
joeleafsfan
Hello, I am creating a titleblock for my compnay and am able to get all the line wights to work properly except when I print out my Text is very faint, almost not readable.  I'm using 9.1 and I know I have all the printer setting correct, wondering if I can change the line weight for the Text?
 Thank You
Fri, Apr 27, 2007 at 10:49:54 AM | Text Line Weight
chriscc
chriscc Avatar
I have the same problem my notes read very faint , I wonder if I should try a diffrent font? any suguestions anyone? thanks
Sat, May 5, 2007 at 11:34:38 AM | Text Line Weight
jrweber25
We are having the same issue.  There is a lineweight parameter in Text properties, but it controls the weight of the box around the text.  They need to add a parameter to control the weight of the text characters themselves.
Model Text line weight override...
Wed, Dec 18, 2013 at 9:47:45 AM
Line weight in family doesn't equal line weight in project
Fri, May 31, 2013 at 2:54:29 PM
Line Weight as Family Parameter
Fri, Mar 16, 2007 at 4:23:58 PM
Making Line Weight a Parameter?
Mon, Mar 19, 2007 at 1:59:55 PM
Column Grid Line Weight
Sun, Aug 13, 2017 at 3:05:53 AM
Page generation time: 3.2947
