28 Users Online (26 Members):
Forums >> Revit Systems >> Technical Support >> Roof offset from level, but why?
6 Posts No Rating |
Hi all,Here's a weird problem. These roof's in my project are offsetting themslves 2m above the level that they are placed on I have copied & pasted them from the original project onto a new blank one. Changing the roof type doesn't help. Any ideas? Cheers, Tania
Edit your roof and select your sketch lines. If you select your lines and go to properties you'll see "Offset from roof Base" is set to 2m. Set to 0 to resolve.
Regards,
Chris.
6 Posts No Rating |
Thanks, thats really great. It had me confounded.
Offset floor same level |
Thu, Feb 12, 2015 at 3:50:34 PM
Roof Cutoff Level/Offset |
Fri, Apr 2, 2010 at 5:09:24 AM
Offset Level of Steel Beams - Start/End or Z |
Tue, Dec 2, 2014 at 10:24:31 AM
Pitch roof problems- double-plumb roofs with different height edges |
Thu, Feb 21, 2008 at 2:54:46 PM
Offset roof by accident |
Wed, May 18, 2011 at 1:11:42 PM
