Forums >> General Discussion >> Revit Project Management >> Imported Revit file visibility
Thu, Apr 26, 2007 at 9:30:56 AM | Imported Revit file visibility
gdelfs
4.5 Stars: 3 Votes
I imported an architectural Revit plan into our Revit Systems central file. Although I frequently needed to open "manage links" and reload the file, we were able to see the floor plan and start our MEP work. I opened the central file today to print some sheets and reloaded the architectural link. The floorplan link appears in the architectural view, but it does not appear in any of the other views or sheets that were created. I opened the visibility graphics and the linked file is checked to be visible. I have been unable to fix this problem. Can anyone offer some advice.
Tue, May 1, 2007 at 1:45:01 PM | Imported Revit file visibility
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
Check to see if the linked file is loaded under File > Manage Links.
Hiroshi Jacobs
The Catholic University of America
Tue, May 1, 2007 at 5:15:20 PM | Imported Revit file visibility
JDahl
Also might try to highlight the linked file then click properties... Default is background, and it gets hidden by your models slabs floors roofs etc., if you change the setting to foreground it will show through.
imported DWG visibility
Fri, Apr 13, 2007 at 12:26:22 AM
Imported .dwg File Visibility Settings
Mon, Mar 14, 2011 at 5:29:06 PM
Annotations accidentally snapped into linked dwg (Imported categories)
Tue, Jul 9, 2013 at 5:53:11 AM
imported revit structure and no visibility beneath
Tue, Jan 27, 2009 at 2:29:28 PM
Removing Imported CAD file from Visablity Graphics
Mon, May 15, 2017 at 2:12:28 PM
Page generation time: 3.9961
