Forums >> Revit Building >> Technical Support >> horizontal extension to the handrail
Wed, Apr 25, 2007 at 4:42:35 PM | horizontal extension to the handrail
shiraz
How can I create handrail or guardrail on a ramp or stair with the horizontal extentions on both endsas per ADA?
Wed, Apr 25, 2007 at 6:18:14 PM | horizontal extension to the handrail
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Using a special end baluster.
Go to Load Family-->Then click on the web content link on the popup window OR check your DVD.  There is a sample Revit file full or railings, one full of stairs and one full of repeating detail components that have this presetup.  Then you can simply copy and paste these into your project.
Regards,
Chris.
Wed, Jan 9, 2008 at 1:25:31 PM | handrail extensions
mlohr
mlohr Avatar
I've been working with the different extension and post downloads and am having difficulty using the "offset-start" ones (ie post-round handrail-extension-offset-start and handrail-round-extension-offsest-start).  Whenever I try to edit/set the baluster placement/post properties using the offset-start extensions Revit gives an error that it cannot make the extension...
some of my questions about this are whether it has to do with the original file? with the cut geometry in the family? with the type of railing? with the railing properties? etc....
any suggestions?  has anyone else run into this problem?
Handrail Extension at Top of Stair
Thu, Jul 2, 2020 at 7:32:23 AM
Flip that handrail
Wed, Oct 18, 2006 at 12:48:45 PM
Handrails Flatten When Extended
Fri, May 29, 2015 at 1:11:10 PM
Handrail without Balusters
Wed, Oct 2, 2019 at 4:04:39 PM
Handrail - Wall mounted
Fri, Apr 28, 2017 at 5:35:54 PM
Page generation time: 0.0763
