Forums >> Revit Systems >> Technical Support >> Revit MEP better?
Wed, Apr 25, 2007 at 2:22:27 PM | Revit MEP better?
gdelfs
4.5 Stars: 3 Votes
Has anyone had a chance to work with the plumbing in Revit MEP. I am curious about whether it is as improved as our dealer has promised. I would appreciate any reviews of it that anyone has. thanks
Mon, May 21, 2007 at 2:56:01 PM | Revit MEP better?
TRGeiser
The plumbing is much better. You are now able to add connectors for HVAC, plumbing, and electrical. It still has a ways to go, however. P-traps do not even exist. Check out what I have been able to do.
Mon, Jul 9, 2007 at 7:32:33 AM | Revit MEP better?
erno
A trap exists in MEP 2008
But, it is a pain to install. It can be done. I just figured it out last week. It does some real weird things on some fixtures. I would try to explain how I did it but, not sure I could. I have connected to floor drains and lavatories. Tried the urinals without success. I tried to attached the model but is was nearly 13MB. When I have some time I will recreate a small portion of the model and post it.
Thu, Apr 30, 2009 at 8:37:34 PM | Revit MEP better?
mrbeandiesel
mrbeandiesel Avatar
1.5 Stars: 4 Votes
try see my plumbing sample, search it on downloads type "plumbing diagram" it was manually made on revitMEP2009
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:49 AM
Revit MEP
Wed, Oct 28, 2009 at 10:10:40 PM
From 2D CAD MEP files to Revit MEP
Tue, Feb 9, 2010 at 11:12:10 AM
Can individual Objects be bound in Arch then changed in MEP
Thu, Jun 7, 2012 at 1:37:23 PM
REVIT MEP - Separate models for MEP disciplines
Tue, Jun 25, 2013 at 1:45:42 PM
Page generation time: 5.3698
