13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> VISIBILITY PROBLEMS
Hi! I am working in Revit Builidng 8.1 and when I am in the ground level I can see everything less part of doors and several 2D families that I made myself!! I was playing with the levels of visibility ( bottom, cut, top, view depth) but doesn't work... Could someone help me?!!! Thanks very much!
Not sure I understand exactly what your problem is (what is it you don't want - or want - to see?). But one thing I always check when I have view range problems is the "Underlay" property in the View Properties dialog. If it is set to anything other than "none," you may see more than you want to see. I've also noticed that some 2D families show through visibility ranges for some reason. You can use the line work tool to get rid of the lines, but I'm not sure how to get rid of text in those types of families.
Could you post the families and we can look and see if we can find some visibility problems that might occur?
as well as the other suggestions here, one thing to look out for especially on window and door families, is the visibility of symbolic lines. i tend to make these 'show only if instance is cut', otherwise they can appear in every view.
Thanks latemore. That solves one of the problems I've been having too!
Ja! Thanks! Latemore!!! For me it also works!!
you are both welcome. we are all on revitcity to help each other! peter
visibility graphics problems-please help! |
Sat, May 28, 2011 at 4:33:53 PM
Visibility Problems |
Sat, Jun 13, 2009 at 2:17:06 AM
VG problems with uploaded beam family |
Tue, Aug 28, 2007 at 6:49:43 PM
HELP!!! Problems with Room Tag |
Tue, Dec 3, 2013 at 7:17:38 AM
Problems with visibility parameters |
Tue, Sep 23, 2008 at 9:01:12 AM
