12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> line weights, elevations, and clipping
69 Posts No Rating |
ok so here is my problem. i have created a bunch of interior elevations and the limit line of the clip in the elevation is creating havoc on my wall and floor line weights. if i pull the clip line back the walls have a heavy lineweight as they are being cut. when the clipping box is snapped to the face of the wall it loses its lineweight, same for the floor! am i doing something wrong? thanks for your help! pgrimmi
along similar fronts, is it possible tobreak an elevation so that it staggers and does not cut through some casework that i want to avoid?
otherwise, i will have to go into each elevation and adjust the crop region so that the correct lineweight shows up. seems like this should be something basic that can be easily corrected! thanks again! pgrimmi
exterior elevations and line weights |
Fri, Jul 20, 2007 at 12:06:07 PM
Line weights reverting to standard |
Thu, Jan 6, 2011 at 7:10:38 AM
Revit Structure Questions Line Weights |
Wed, Jan 16, 2013 at 3:33:32 PM
A Nice set of Revit Line Weights |
Wed, Jun 20, 2007 at 8:47:36 PM
Line weights & detailing 2012 |
Thu, Jun 6, 2013 at 7:51:24 PM
