Forums >> Revit Building >> Technical Support >> Linking ADT imports
Tue, Apr 24, 2007 at 11:18:53 AM | Linking ADT imports
hippy
I use .dwg as a base to draw on top of. I have recently been linking instead of importing. But today my drawing is really dragging bad. After some investigating I beleive I have decided that my import was an ADT drawing, because walls etc had different starting and ending z points. The auocad I use shows deffinate heights to walls and door blocks but nothing looks right.
All I care about is making my Revit drawing work right, I am half a day into a drawing I would have liked to finish in less than 4 hours and have 30 to go at this pace. I tried flatshot. I tried exploding. I haven't yet tried unlinking, but thats probly next.
Tue, Apr 24, 2007 at 3:20:40 PM | Linking ADT imports
pgrimmi
did you want to be sure that relinking the dwg was the best course? we used the same method for creating our model and for the most art, it has worked out well. you can use the manage links command to reload the acad dwg.
Bringing ADT lines into a Revit Model
Wed, Mar 4, 2009 at 6:56:22 AM
REVIT X ADT
Sun, Jan 8, 2006 at 10:40:42 PM
CAD symbol imports
Mon, Sep 11, 2006 at 5:24:42 PM
ADT VERSUS REVIT
Tue, May 15, 2007 at 2:07:40 PM
11
Revit vs ADT?
Tue, Nov 27, 2007 at 4:35:37 AM
Page generation time: 0.0547
