17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Rendering question
Hi all,
I created a model and when I rendered it I not sure what happened. Take a look at the attached doc. You will see in the second shot what I'm talking about. As you can see from the first shot the drive goes down to the garage under the house, but in the rendered view its cover under the gray horizion. The gray horizon is at level 0'-0" if this helps. I'll be happy to mail the drawing to anyone willing to help.
Cheers, Alan
62 Posts No Rating |
most likely you have a ground plane turned on by default. to turn it off do this:
under the 'veiw' menu pick 'advanced model graphics' then in the 'sun and shadow settings' area pick the dine arrow just to the right. In this window there is a check box near the bottom for 'ground plane' either un check this or reset the level for it to display at.
Thanks, that did the trick, but now I can't see the topo I added........I checked the properties box and it's turned on......
Never mind.....I created the topo in New Construction and forgot to change the Phase setting to show completed.....DAHHHHHHH Thanks agian.
NEWBIE QUESTION... RENDERING?? |
Fri, Jul 23, 2010 at 2:03:16 PM
rendering |
Tue, Sep 21, 2010 at 9:45:53 PM
NEWBIE Question: Confused about rendering... |
Mon, Mar 2, 2009 at 11:46:53 AM
Rendering Question |
Mon, Apr 30, 2012 at 7:55:09 AM
Rendering... |
Fri, Aug 8, 2008 at 2:43:22 AM
