Forums >> Revit Building >> Technical Support >> Editing Font on titleblocks below elevations/plans on sheets?
Mon, Apr 23, 2007 at 3:54:20 PM | Editing Font on titleblocks below elevations/plans on sheets?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
When I setup my sheets with elevations and plans they go in great but the problem I'm having is when I print them out the title below the plans or the elevations is way too small and isn't readable.  I've tried looking at its properties but it seems to be part of the sheet itself and won't let me edit it.  I need the font to be bigger and I need it to be a certain font.  Thanks for any and all help! =)
Dominic
 LHAA
 Licata Hansen Associates Architecture
Reno, NV USA
Mon, Apr 23, 2007 at 5:21:06 PM | Editing Font on titleblocks below elevations/plans on sheets?
puzzle
4 Stars: 10 Votes
Are you talking about the View Title. If so, to edit it, go to your Project Browser and scroll down to families. Open up Families, go to Annotation Symbols, scroll to View Titles pick the one that you need and right click and edit. When finished editting, load back into project.
Macca
Sunshine Coast
QLD Australia
Mon, Apr 23, 2007 at 8:27:20 PM | Editing Font on titleblocks below elevations/plans on sheets?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
Yeah I think so I'll try this and let you know how it goes.  Thanks for the help =)
 LHAA
Reno, NV USA
Thu, Apr 26, 2007 at 5:08:58 PM | Editing Font on titleblocks below elevations/plans on sheets?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
I did everything you said but once I got to view title the only thing under it was view title and it didn't have any properties or anything I  could edit.
What I'm talking about is what I've attached.  I hope this helps or works. =)
 LHAA
Reno, NV USA
Thu, Apr 26, 2007 at 10:32:15 PM | Editing Font on titleblocks below elevations/plans on sheets?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You're in the wrong spot... Smile
Your project browser on the left of screen...
Expand Families-->Annotation Symbols-->you'll have something in here called view title.
Edit that family and adjust font sizes etc as necessary and either save as new name or just load in and overwrite the one in your project.
Regards,
Chris.
Mon, Apr 30, 2007 at 12:27:55 PM | Editing Font on titleblocks below elevations/plans on sheets?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
Ok so I got this far... but now how to edit the family?  I know this is simple stuff... sorry I'm having trouble.
 LHAA
Reno, NV USA
Mon, Apr 30, 2007 at 1:23:44 PM | Editing Font on titleblocks below elevations/plans on sheets?
blake
3 Stars: 2 Votes
In your Component Library under annotation the view title it located there and you can then edit the family to appear how you would like.  Load it into you project.  In your sheet select the view click properties Edit/New.  Under Title select the view Title you just loaded.  Read the other options and see if you want those changed.  Click OK and you should be set.
Mon, Apr 30, 2007 at 2:16:16 PM | Editing Font on titleblocks below elevations/plans on sheets?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
Ok I finally got it!  I was right clicking the View Title after I pulled the main one down and it wouldn't let me edit them but when I right clicked on the main View Title before I pulled the view title menu down it allowed me to edit the family and load it after I made changes!  Thanks alot guys!
 LHAA
Reno, NV USA
Tue, May 22, 2007 at 4:42:51 PM | Editing Font on titleblocks below elevations/plans on sheets?
pleasantc
How do you load the new View Title you've created so that it appears in that Title box so you can select it? I've loaded it - it shows up in the Project Browser - but when I click on Title, (after clicking Edit/New) it doesn't show up. What am I missing?!
Tue, May 22, 2007 at 4:46:36 PM | Editing Font on titleblocks below elevations/plans on sheets?
pleasantc
Never mind, I got it.
Titleblocks
Mon, Mar 17, 2008 at 3:03:10 PM
Font
Thu, Feb 25, 2016 at 6:39:37 PM
Rendering Plans and/or Elevations
Mon, Feb 7, 2005 at 12:46:11 AM
Hiding Elevation Keys - Clipping Elevations
Thu, Jun 21, 2007 at 9:52:28 AM
Elevations and plans all messed up
Mon, Dec 16, 2013 at 1:50:42 PM
Page generation time: 5.3510
