Forums >> Revit Building >> Technical Support >> Duplicate views - turning off work in main view
Mon, Apr 23, 2007 at 6:04:38 AM | Duplicate views - turning off work in main view
bdbhoy
1 Stars: 1 Votes
I have created a duplicate view in plan to produce electrical information.
I do not want the information to appear on the main plan view, which it is at present.  I'm sure their is a simple way of turning this info off, but can't seem to find it.  Any help?
Mon, Apr 23, 2007 at 6:38:42 AM | Duplicate views - turning off work in main view
Dgodfrey
4 Stars: 4 Votes
Next time, do not duplicate with detail, only duplicate. For now, you can either turn off all annotation in your visibility settings or select an item you don't want to show and isolate the catagory. Now you can window/delete. Do this for each group of elements. You have to reset your temporary hide/isolate settings between to see the effect.
Mon, Apr 23, 2007 at 6:43:11 AM | Duplicate views - turning off work in main view
bdbhoy
1 Stars: 1 Votes
I duplicated the views with no detailing.
Mon, Apr 23, 2007 at 8:35:00 AM | Duplicate views - turning off work in main view
Jerome111
3 Stars: 2 Votes
In your electrical plan...the electrical components and line work must be done using drafting lines from the drafting tab. These line are view specific and will not show up in any other view.
Mon, Apr 23, 2007 at 8:57:13 AM | Duplicate views - turning off work in main view
Enginator
5 Stars: 2 Votes
Well, "electrical components" like wall switches/outlets are families and show up wherever they are turned on.  The visibility settings in View-Properties are view specific.  Just turn off/on the electrical components for each view as desired.  But the symbolic "wires," as mentioned, do need to be lines, which are view specific.
Mon, Apr 23, 2007 at 9:13:13 AM | Duplicate views - turning off work in main view
bdbhoy
1 Stars: 1 Votes
I assume that explains the electrical items (and lines) keep appearing in the main view and subsequent duplications. I've 'botched' something together using the useful view/temp hide tool and filtering the views complonents, but it's not the most elegent or I suppose correct method.
Thank for the help.
Unable to duplicate a view
Tue, Sep 13, 2011 at 6:44:21 PM
Turning off one object in all views with one step?
Thu, Mar 27, 2008 at 4:58:50 PM
Duplicate views create duplicate callout tags in referring views...
Fri, Mar 9, 2012 at 1:37:25 PM
Error Converting Dependent View to Independent View RAC 2009
Fri, Oct 3, 2008 at 8:53:23 AM
Creating duplicate views of elements
Tue, Apr 24, 2012 at 5:57:37 AM
Page generation time: 0.9547
