38 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Sweep Profiles and Path's Not Visible
Sun, Apr 22, 2007 at 11:26:18 AM | Sweep Profiles and Path's Not Visible
Enginator
5 Stars: 2 Votes
Ive created an in place sweep.  The sweep was created in the East view.  I've found I need to change the sweep profile.  When I try to edit it, the existing profile is not visible, and any new geometry I create gets a "the element created is not visible..." warning.   It's not even visible in the 3D view.  However, I can edit the path when in the East view only.
 There is also another sweep I created in the plan view.  I can't edit that path in ANY view, not even plan.  Nor can I edit the profile on that one in any view.
 I have made sure that the mass category that I used for the in-place mass is visible in all views. I can also see the created mass in all views - just not the pink-colored path line or editable profile line.  The black place holder path line and profile lines ARE visible, however.  They go away when I click "sketch 2d path" or "sketch 2d profile."
 Any ideas?
Sun, Apr 22, 2007 at 6:20:21 PM | Sweep Profiles and Path's Not Visible
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Sounds like you have "lines" turned off in your visibility settings-->Model tab.  They need to be turned on in order to see your sketch.
Check this.
Regards,
Chris.
Mon, Apr 23, 2007 at 7:59:28 AM | Sweep Profiles and Path's Not Visible
Enginator
5 Stars: 2 Votes
That was it.  Thanks!
Sweep Profiles in Version 9
Thu, Aug 3, 2006 at 2:14:05 AM
Multi-profile Sweep
Fri, Jan 22, 2010 at 8:08:14 AM
Sketch a path greyed out...can't alter sweep path
Mon, Jul 26, 2010 at 4:45:05 PM
Can't make sweep path by picking on 3D edges.
Fri, Jun 13, 2014 at 4:32:04 PM
3D path insteads of 2D path
Mon, Mar 28, 2005 at 9:23:38 PM
Page generation time: 7.7196
