15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> sandwich panel
Hi All, can any one provide or help me find the below. 1.sandwich panel 2.typical "Z"section profile / family 3.typical "C"section profile / family also can any one tell me if i can use massing for steel structure framing or is there any otherway out. i am using revit building 9.1 thnaks in advance. bjwson
Unfortunately our library has now been upgraded to 2008 so i can't help out with the families. When doing steel structure framing use your beams and beam systems tools not massing. with your sandwich panel we would just model it as a flat profile roof using the roof tool. In section would add a repeating detail component as necessary at finer scales. HTH.
Regards,
Chris.
Fabric area for sandwich precast pannels |
Sun, Jun 17, 2018 at 4:24:44 PM
Revit 2009 Wall Base Extension |
Fri, May 2, 2008 at 12:23:39 PM
Building Arabic style panel |
Tue, May 26, 2015 at 9:48:09 AM
customerized curtain panel doesn't work with the irreglar shaped panel? |
Sat, Jul 10, 2010 at 1:48:42 PM
Newb Question: Tilt Up Panel |
Fri, Apr 16, 2010 at 1:00:49 PM
12
