Forums >> Revit Building >> Technical Support >> View Title Extension line
Fri, Apr 20, 2007 at 7:00:08 PM | View Title Extension line
daleyy
We have a thicker line in our View Title than the one that Revit puts into the extention line of the View Title.  Is it possible to lock a filled region of the View Title to the extension line so that the filled region moves with the extension line?  The filled region is a rectangle.  The ends are not rounded like the extension line is if you give the extension line a thicker lineweight.
Thanks
DaleW
Sat, Apr 21, 2007 at 5:33:20 PM | View Title Extension line
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
you could include the filled region in your view title tag... however it would have to be a fixed length...  Unless you made new view title types for each length of text.    I dont believe there is a way to have this link to the view title drag...
You could try setting its length as an instance parameter between two reference planes and maybe you'll get a dragable extension when selecting the view title.  Not sure as i can't test this at the moment as i don't have revit on this computer.
Regards,
Chris.
Mon, Apr 23, 2007 at 10:32:11 AM | View Title Extension line
daleyy
I will try the ref line idea.
Thank you Mr. Spot
DaleW
Mon, Apr 23, 2007 at 5:14:38 PM | View Title Extension line
daleyy
Everything I tried with a parameter did not work.  I even tried to lock the filled region to a ref Plane and then dimension the plane from the insertion point of the tag.  I was hoping to get a dimension option in the properties box, but that did not do it either.
 If you have any other suggestions it would be great otherwise, I will have to see if I can do it a different way.
Thanks
DaleW
Mon, Apr 23, 2007 at 6:06:28 PM | View Title Extension line
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I just tried it and they only way to do it is with a type parameter.  Which is rather annoying as you would need to create a new view title type for each length line...
The parameter won't display in your view title properties, it will be in your project browser-->Families-->Annotations Symbol-->Your View tag-->Your View tag type Properties...
HTH.
Regards,
Chris.
Mon, Apr 23, 2007 at 6:07:43 PM | View Title Extension line
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Another option would be to create an annotation symbol that you place separetly on each sheet that has an instance parameter for length...
Regards,
Chris.
Mon, Apr 23, 2007 at 6:38:22 PM | View Title Extension line
daleyy
I got it to work with Family types and a parameter linked to the dimension. I then realized that I would have to create different viewports with the various Family types of the view title in it.  Bit of a pain but would work.  I will see what the senior staff thinks of the options.
Thanks for the help Mr. Spot
DaleW
Deleting View Title Extension Line.
Thu, Dec 27, 2007 at 10:06:05 AM
View title extension line grips trouble
Wed, Oct 9, 2013 at 2:04:27 PM
Automatic View Title Extension Length
Sun, Dec 18, 2016 at 5:45:56 PM
View Title Extension Lines
Fri, Dec 10, 2010 at 3:03:17 AM
Control Line in View Title Tag
Mon, Jun 11, 2018 at 7:45:48 AM
Page generation time: 1.0327
