Forums >> Revit Building >> Technical Support >> Sun on Elevations
Fri, Apr 20, 2007 at 3:07:11 PM | Sun on Elevations
mvan1
i am currently using Revit 2008 and when i go to my elevations and turn on shading with edges the massing colors that show up are much lighter than what i chose in my material settings.  Is the sun shining on that elevation causing it to be so bright?  If so, how can i turn it off?  I would like to have the elevations in the colors i chose when i set up the materials.  Thank you very much.
 Matt
how doing elevations without sun ?
Fri, Jan 28, 2011 at 10:13:09 PM
rotating a horizontal sun shade to a vertical sun shade
Fri, May 12, 2006 at 1:14:08 AM
Triangle sun sail
Fri, Aug 23, 2019 at 7:40:27 AM
Rendering - Tame the Sun
Fri, Jun 4, 2010 at 4:36:35 PM
Artificial Sun
Sat, Jan 31, 2009 at 3:31:32 PM
Page generation time: 0.3144
