Forums >> Revit Structure >> Technical Support >> Spot Dimension Text
Fri, Apr 20, 2007 at 8:08:22 AM | Spot Dimension Text
bdel
Is there a way to add text to the top or bottom of a spot dimension?  For example:  I would like to have top of wall above the extension line and the elevation below.  Thanks
Tue, Jan 20, 2009 at 10:58:18 AM | Spot Dimension Text
FJ22
hi, when you look at the element properties there's a section called text.
There you can change the display elevation (top, bottom or both). Underneath that there are a couple of lines where you can add a value prefix or suffix.
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
Overwriting Dimension with Text
Thu, Jan 11, 2007 at 11:13:56 AM
Multiline text below dimension
Tue, May 10, 2011 at 9:32:42 AM
Dimension Text Problem
Fri, Nov 14, 2008 at 9:41:55 PM
Inserting text under dimension in string dimension
Thu, Apr 2, 2009 at 9:47:51 AM
Page generation time: 1.5964
