Forums >> General Discussion >> Revit Project Management >> Central file past its end
Thu, Apr 19, 2007 at 9:54:32 AM | Central file past its end
gdelfs
4.5 Stars: 3 Votes
When trying to save to central or access the central file we recieve this error.
An attempt to access 060153 Central.rvt past its end.
Has anyone seen this before? Does anyone know of any solutions/causes for this? I don't want to lose the work we have done in our individual "save as" links. Please help.
Thu, Apr 19, 2007 at 6:18:07 PM | Central file past its end
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Unfortunately "past its end" is one of the worst errors you can come across.
Contact Autodesk support and see if they can repair the file, but most likely it will be unrepairable.  Best bet is to find a local file or a backup that you can open that has the least missing information...
I can't remember what the cause of this error is either...
Regards,
Chris.
can not save a central file
Thu, Mar 20, 2014 at 2:28:30 PM
Hosting to Ceilings linked from Architects Central file
Thu, May 19, 2011 at 1:17:15 PM
Error Message
Wed, Oct 10, 2007 at 10:46:59 AM
File is "past it's end"
Wed, Dec 19, 2007 at 9:35:12 AM
detach from central file
Wed, May 12, 2010 at 12:28:23 PM
Page generation time: 0.5459
