22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Section View with Missing Earth Hatch
6 Posts No Rating |
Recently, the section sheets in my building file have been missing the earth hatch in the area directly below the building. It is as if the pad has been pulled all the way down to sea level, however, this is not the case. I have a seperate site file that is linked to the building file. In the site file, the pads show up in the appropriate place and on the appropriate level. When I cut a section, the hatch shows up as it should?!?!? Has anyone experienced this problem before and found a solution other than placing a filled region to fix every sheet? Thank you, John
6 Posts No Rating |
OK so I'm going to reply to my own post...for some reason when I change my print settings from vector to raster the Print Preview shows the hatch correctly. This is a solution, but not a great one because it makes the plot files huge and timely to print. I am led to believe that this is a glitch in the program caused from linking 2 revit files. If anyone know's different I would love to hear your thoughts.
Earth and Wall cut patterns not showing in wall section... |
Thu, Jan 5, 2012 at 3:08:36 PM
Earth Hatch |
Tue, Nov 29, 2011 at 5:23:49 PM
Show earth hatch in sections, but not in elevations? |
Thu, Oct 29, 2015 at 7:45:45 PM
Basement filled with Earth Hatch |
Mon, Feb 24, 2014 at 2:04:34 AM
Earth hatch |
Tue, May 13, 2008 at 11:39:59 AM
