Forums >> Revit Building >> Technical Support >> Wall reveal on wall ends?
Wed, Apr 18, 2007 at 3:17:03 PM | Wall reveal on wall ends?
iREV
3.5 Stars: 3 Votes
I am having problems with vertical wall reveals on the end of walls.  The problem occurs where the walls join at corners.  Anyone have any sloutions?
Wed, Apr 18, 2007 at 4:08:00 PM | Wall reveal on wall ends?
Does the reveal turn the corner?   If it does, they will clean up.  Sometimes you can drag the end to help that happen.
If the reveal does not turn the corner, you may have a problem depending on how you have your walls joined.
Thu, Apr 19, 2007 at 10:01:06 AM | Wall reveal on wall ends?
Jhui
I have trouble with wall sweeps turning corners, they don't seem to join properly.
how to add a self made reveal to a wall while edit wall types?
Sat, Feb 12, 2011 at 10:53:31 PM
Splitting a wall with a Reveal
Fri, Feb 19, 2010 at 11:25:44 AM
Wall Reveal by Face in 2010
Wed, Apr 7, 2010 at 10:20:06 AM
REVEAL help, reveal turning a corner at end of wall??
Tue, Jun 5, 2007 at 2:25:20 PM
Wall Reveal-Please HELP!!!!!
Fri, May 26, 2006 at 9:12:01 AM
Page generation time: 1.4270
