Forums >> Revit Building >> Technical Support >> Is it Possible to use CTRL or ALT or SHIFT in the Keyboard Shorcuts.txt?
Wed, Apr 18, 2007 at 9:39:07 AM | Is it Possible to use CTRL or ALT or SHIFT in the Keyboard Shorcuts.txt?
keene
It would make life a lot smoother if it were possible to use the CTRL, ALT, and SHIFT buttons in the Keyboard shortcuts.txt. Archicad has that capacity. Its really annoying to have to constantly either use one hand to type out commands slowly or take the other hand away from the mouse to type.
Wed, Apr 18, 2007 at 10:54:38 AM | Is it Possible to use CTRL or ALT or SHIFT in the Keyboard Shorcuts.txt?
daleyy
I 100% agree with this.  Most if not all other programs that is used in AEC industry has this capability.  But instead we in Revit are only STUCK with two keystroke shortcuts.  Very unfortunate.
DaleW
RST 2010 keyboard shortcuts - TXT file vs Options list
Thu, Feb 11, 2010 at 8:33:17 AM
Ctril and Shift not working
Mon, Jan 20, 2014 at 12:52:49 PM
Customisable keyboard shortcuts
Thu, Apr 21, 2005 at 6:54:01 AM
using contol or option keys when setting hot keys?
Mon, May 18, 2009 at 4:47:26 AM
The "Alt" key
Mon, Sep 21, 2009 at 5:25:25 AM
Page generation time: 1.6805
