Forums >> Community >> The Studio >> Revit drafting modeling and rendering services
Wed, Apr 18, 2007 at 3:48:35 AM | Revit drafting modeling and rendering services
binojkumar
Dear Sir,
We are an Architectural BPO providing Architectural services all over the  globe.We have a dedicated and energetic team for delivering the drawings within the specified time frame specified by the client. Our team members have good experience on international standards.They are well  experienced in preparing the rennovation drawings and Architectural working  drawings in  Revit from your conceptual sketches.Our 35 member team consists of Architects,draftsmans and marketing members.
Our company is located on the southern most part of India called Kerala which is otherwise called as "God's own country".It is located in a 3 storied buiding situated in the mid of the city called Trivandrum(Capital of Kerala).
File transferring can be done through email, fax or FTP.These files are processed by our technical team they inturn will update you on daily basis regarding the process of our work.We will assign a team for each and every project which varies according to the work load and time barrier.The updation of your project will be done by our technical head through phone or any messenger devices and by sending our progress files.
Our technical team is well versed with AIA, BS and NCS standards.We will work according to your proposed CAD standards.
For projects we will be working on regular shifts for assuring our client that the deadlines are well kept.
We are charging on hourly basis at the rate of 10 USD per hour. For example,for developing the Architectural working drawings of a 3000 sq foot building we charge only 540 USD.
We are positively looking for your project to prove ourselves and building up our relation so that we can work together as a team.
How We can work together as a Team
The initial steps are to send us the following: • Sketch / Paper Drawings / Reference Drawings• Local Libraries• Required Turnaround time
The files can be sent in any graphic format, such as TIFF, JPEG or even PDF. Paper drawings can also be couriered to our office. AutoCAD or ArchiCAD drawings can also be emailed to us.We stick to Drawing Standards as prescribed by you. However we can also use default standards such as AIA guidelines
Communication can be done by email, phone, by fax or online chat. We can do the file transfer through FTP.We will setup an FTP site for you for easy file transfer.
The paper drawings can be scanned starting from 150 DPI – 200 DPI, however the most important part is the clarity of the information to be sent.
The turnaround time depends totally on the project as well as the output required. We can also work on short deadlines if required.
We do not disclose any computer & paper data generated by us or sent to us during any project.
We have very fast internet services and can transfer a huge amount of data through the Internet. We can also burn a CD and post it to you as per your convenience.
These Net Enabled services are covered under WTO agreement and are signed by more than 110 countries around the Globe.
Our CAD Services assures the highest degree of quality and accuracy for each CAD file. Files are checked and rechecked to make sure that all standards were followed and that the document was drafted / converted accurately.
SERVICES WE PROVIDE
Architectural Working Drawings
2D CAD Drafting
Detail Drawings
Construction Documents
3D Modeling
Rendering
Paper to CAD conversion
Raster to Vector Conversion
GIS
Mechanical CAD drawings
Shop Drawings
Structural Drawings
Electrical CAD drawings
HVAC
Plumbing Drawings
Fabrication drawings
Animations
Perspective Views
Walkthroughs
Please provide us your contact number so that we can discuss together.
Awaiting for your positive reply at the earliest,
BINOJ KUMAR G,
gbinojkumar@gmail.com
Cloud Rendering Services
Mon, Sep 10, 2012 at 2:53:50 PM
Revit modeling services provided [ 1 2 ]
Sat, Jun 27, 2009 at 3:13:55 AM
16
Drafting modeling and rendering service using Revit
Thu, Oct 5, 2006 at 3:15:09 PM
Gain efficiency with Revit Structure Drafting, 3D Modeling Services
Thu, Jun 18, 2009 at 12:45:00 AM
Revit drafting service
Sat, Jan 17, 2009 at 7:35:30 AM
Page generation time: 1.4388
