Forums >> Revit Building >> Technical Support >> REVIT Building 9.1: viewport and scale on dwg sheet
Tue, Apr 17, 2007 at 4:04:32 PM | REVIT Building 9.1: viewport and scale on dwg sheet
leechriz
I am having having problem adjusting the size and scale of viewport on drawing sheet. i am trying to put two viewports on the same sheet: one for enlarged room plan (1/2" scale) and one for floor plan with (1/8"Winking. can anyone help?
Tue, Apr 17, 2007 at 4:34:27 PM | REVIT Building 9.1: viewport and scale on dwg sheet
Not AutoCAD - no viewports - just views.
 You can set the scale of each view from within the view.  You can get there by opening the view from your browser or you can place the view on the sheet (any-where) then right click in it and choose "activate view".  Now you can set your scale.
If you need to adjust the limits of your views, get into the view & right click to choose view properties.  From there you can adjust your view crop regions.
Beginner Question with Scale on Viewport
Tue, Oct 19, 2010 at 2:49:52 PM
downsizing a viewport
Thu, Jul 8, 2010 at 7:03:43 AM
Scaling Viewports
Tue, Feb 18, 2014 at 8:32:35 AM
Draw Order of Viewport on a sheet
Wed, Dec 16, 2009 at 4:35:58 PM
Multiple Viewport Titles in same sheet
Wed, Jul 30, 2008 at 7:16:18 PM
Page generation time: 1.6145
