Forums >> Revit Building >> Technical Support >> imported autocad 3d block, how to remove line work?
Tue, Apr 17, 2007 at 1:20:47 PM | imported autocad 3d block, how to remove line work?
bradmac
3 Stars: 1 Votes
i downloaded an autocad kohler water closet and imported it into the revit family editor.  is there a way to get rid of the unwated linework?  i am attahcing the family.
 thanks
Tue, Apr 17, 2007 at 2:46:19 PM | imported autocad 3d block, how to remove line work?
coreed
coreed Avatar
4 Stars: 16 Votes
why not get rid of unwanted linework before importing in Revit
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Apr 17, 2007 at 3:29:05 PM | imported autocad 3d block, how to remove line work?
bradmac
3 Stars: 1 Votes
here is the original autocad block.....i don't think you can.
Tue, Apr 17, 2007 at 10:19:07 PM | imported autocad 3d block, how to remove line work?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Revit will always show all the triangulations of a imported 3D DWG file.  To get around this its best to set the 3D geometry to not display in plan or section and then create masking regions (white filled regions pre 200Shadey so as they conceal elements behind them and to represent the element in these views.
HTH.
Regards,
Chris.
Wed, Apr 18, 2007 at 9:36:49 AM | imported autocad 3d block, how to remove line work?
bradmac
3 Stars: 1 Votes
i figured that was what i had to do.  there is no way to hide the triangulation lines in autocad?
Wed, Apr 18, 2007 at 9:43:24 AM | imported autocad 3d block, how to remove line work?
bradmac
3 Stars: 1 Votes
you can't create filled regions in a plumbing category, do you do it in the project?
Wed, Apr 18, 2007 at 10:11:18 AM | bradmac
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting bradmac from 2007-04-18 09:36:49
"i figured that was what i had to do.  there is no way to hide the triangulation lines in autocad?"
here is your original file with a hidden triangulation version next to it done in Autocad. i don't distinguish between Autocad and Desktop and that sometimes creates problems. i should have said Desktop.
sorry for the misunderstanding
HTH
Edited on: Wed, Apr 18, 2007 at 2:18:22 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Importing AutoCAD Title Block Line Thickness Problem
Wed, Feb 20, 2013 at 1:40:15 PM
Imported AutoCAD 2006 title block line thickness
Thu, Sep 7, 2006 at 3:27:44 PM
Revit 2014 Imported Linework
Wed, May 14, 2014 at 1:16:55 PM
How to import my title block from AutoCAD?
Mon, Sep 10, 2007 at 4:25:43 PM
12
Uin note block
Thu, Dec 3, 2015 at 7:06:54 AM
Page generation time: 1.2680
