23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> re-joining (?) cut extrusion with extrusion
Hi. Please teach me how I can "reassociate" (or whatever the correct term would be) a cut extrusion to a extrusion after I mirrored it. The error I received was "Can't keep elements joined." when I mirrored a table base in a family I'm creating. In the new epice it still shows the rectangle extrusion with the goasted cut extrusion around it but it is not cutting the extrusion anymore. Thanks!
Use the cut geometry tool. Pick the void then the element you want it to cut.
Regards,
Chris.
Cut a void from an extrusion |
Thu, Feb 19, 2015 at 1:08:44 AM
Joining Roof By Extrusion |
Mon, Jan 31, 2011 at 8:15:14 AM
Void Won't Cut Extrusion |
Wed, Feb 13, 2013 at 11:04:26 AM
void extrusion not cutting solid extrusion |
Fri, Oct 10, 2008 at 3:47:43 PM
Can I cut a hole through an extrusion? |
Fri, Apr 13, 2007 at 8:31:51 AM
