Forums >> Community >> The Studio >> In Place Families???
Tue, Dec 21, 2004 at 2:17:50 PM | In Place Families???
jstewart
When creating an in place family is it ok to copy them around? Or is an "in place family" only meant to be drawn once and not copied or moved? Some people in our office who are just learning Revit are complaining about the fact that when creating a family they do not have the building to reference by. So they want to do an "in plcae family" for an object and copy it around. This seems fine but when the sketch was edited it moved one of the copied objects back to the plane the origional was origionally drawn on. Has anyone else had this problem or have any recomendations!
Tue, Dec 21, 2004 at 5:11:34 PM | RE: In Place Families???
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Basically the rule i go by is, If it is going to be used more than once it should be an external family. As by copying an in-place family it is not associated to the other object. That is; change one and the other will not change! I'd cut and paste the geometry from the in-place family to an external family and use that.
Filter for in-place families
Tue, Jan 22, 2013 at 8:49:24 AM
Materials for in-place families
Wed, Jul 29, 2009 at 7:07:59 PM
In place families above the view range are still appearing
Tue, Dec 23, 2014 at 9:17:05 AM
Massing Vs. In-Place Families
Fri, Jul 17, 2009 at 7:23:22 AM
Why In-Place Families?
Sun, Nov 21, 2004 at 5:51:42 PM
Page generation time: 0.3887
