Forums >> Revit Building >> Technical Support >> Back-up files and local files
Mon, Apr 16, 2007 at 4:32:01 PM | Back-up files and local files
minderoo
3 Stars: 2 Votes
I'm having a problem getting Revit to save back-up files of my local files.  When I'm the only user and we haven't created worksets, it creates plenty of backups, but once we set up worksets and start working from a local file, it creates a folder called (jobname)_backup, but no actual backup files.  Is there a setting I'm missing?  Thanks!
Mon, Apr 16, 2007 at 6:47:15 PM | Back-up files and local files
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
How are you accessing the backups?  Backups are best accessed through File-->Backups... then selecting the appropriate file and a list of backups should display allowing you the option to rollback.
HTH.
Regards,
Chris.
Tue, Apr 17, 2007 at 8:19:10 AM | Back-up files and local files
minderoo
3 Stars: 2 Votes
Thanks!  I guess I missed that.  Since all of the other files create a .001, .002 type extention, I thought it was the same thing.  Have a nice day! :o)
How many local files to keep??
Tue, Oct 6, 2015 at 4:05:44 PM
BACK UP FILES WITH WORK SHARING
Wed, Apr 28, 2010 at 10:05:09 AM
Deleting local files and copying files from central
Fri, May 23, 2008 at 11:28:55 AM
Local files keep becoming incompatible with central file!
Thu, Oct 28, 2010 at 9:39:23 AM
No rollback files or backup .rvt files
Mon, Jun 27, 2011 at 2:56:14 AM
Page generation time: 1.5387
