Forums >> Revit Building >> Technical Support >> Open type fonts? Can you convert to true types?
Mon, Apr 16, 2007 at 10:30:12 AM | Open type fonts? Can you convert to true types?
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Have downloaded Adobe Graphite Std fonts.  They come in as open type.  I can't get Revit to find them.  Any suggestions?
Mon, Apr 16, 2007 at 7:04:50 PM | Open type fonts? Can you convert to true types?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Revit uses any font that is installed in windows.
Install the fonts in Control Panel-->Fonts then restart revit.
Regards,
Chris.
Tue, Apr 17, 2007 at 7:39:03 AM | Apparently Revit only uses Truetype fonts.
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Autocad is the same.  Windows can uses both truetype and opentype but not Autodesk products.  I purchased three Adobe Graphite STD fonts, installed them exactly as you described, made sure they are in WINNT font directory, but Revit and Autocad can't use them.  A number of similar but not as neat fonts are available free as truetypes, installed them the same as the opentype fonts and Revit/Autocad finds them no problem.  I am now negotiating with Adobe to try to get a refund.
Tue, Apr 17, 2007 at 7:42:01 AM | Here is one attached, see if you can get it to work.
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Maybe there is some dufus thing I am doing.
Tue, Apr 17, 2007 at 11:03:21 AM | Found a solution!
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
We used fontcreator (shareware free for 30 days, $79 after that) to save the opentype (.otf) fonts as truetype (.ttf) ones.  We were even able to modify the funny looking "9" in Graphite to look better.  Works great in Revit and Autocad.
fonts
Thu, Feb 24, 2011 at 2:57:05 PM
Re: True Type Fonts for Revit
Wed, Dec 3, 2008 at 7:52:20 PM
New true type font
Thu, Oct 13, 2011 at 8:23:59 AM
EXPORT to autocad TEXT PROBLEM
Wed, Aug 8, 2007 at 7:28:39 PM
Importing Old Fonts .shx
Fri, Mar 31, 2006 at 11:09:29 AM
Page generation time: 0.7400
