Forums >> Revit Building >> Technical Support >> making space frame in revit.
Tue, Dec 21, 2004 at 4:54:20 AM | making space frame in revit.
emad
I want to make a 3d space frame in revit could any one give some tipe?!!!
Tue, Dec 21, 2004 at 8:06:06 AM | RE: making space frame in revit.
Titania
Quoting emad - 2004-12-21 04:54:20
"I want to make a 3d space frame in revit could any one give some tipe?!!!"
hi,
you can create a curtain wall. the visibility of the glas elements can be turned of at the properties of the view.
titania
Post edited on 2005-06-13 03:52:13
Tue, Dec 21, 2004 at 5:15:38 PM | RE: making space frame in revit.
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Phil Read created a space frame family a while back. Check it out;
GeodesicDome and space frame
Tue, Apr 12, 2005 at 1:37:39 AM
geodesic dome space frame
Sat, Apr 2, 2005 at 7:42:13 AM
Making door frame match Wall thickness..
Thu, Jul 20, 2006 at 6:12:46 PM
Inner space is not surrounded by outer space with higher height.
Thu, Sep 6, 2012 at 8:34:57 AM
HoW CAN İ CUT A SPACE FRAME STRUCTURE ?
Mon, Jan 6, 2014 at 7:27:56 AM
Page generation time: 4.6340
