Forums >> Revit Building >> Technical Support >> creating Ceiling Plans
Fri, Apr 13, 2007 at 5:25:42 PM | creating Ceiling Plans
mead3724
5 Stars: 7 Votes
for some reason my project only created a ceiling plan for my 2nd and 3rd floor, but not for the 1st floor. does anyone know how to creat a ceiling plan if it was not originally created?
Fri, Apr 13, 2007 at 5:59:24 PM | creating Ceiling Plans
TomDorner
4.5 Stars: 25 Votes
Go to View>New>Ceiling Plan
When you copy a level in an elevation or section view, a new plan or ceiling view is not created.
If you place a new level in a view, then on the options bar above the drawing space is a check box that you can toggle on and off to create a plan view and also a button to select view types to create.
Tom
Sat, Apr 14, 2007 at 9:32:47 AM | creating Ceiling Plans
adanedhel
4 Stars: 3 Votes
http://www.dgcad.com/
You can download some basic training movies for free. (Revit, Acad, ADT...etc.)
GL
Sat, Apr 14, 2007 at 5:06:19 PM | creating Ceiling Plans
mead3724
5 Stars: 7 Votes
Thanks for the help. I got it figured out but could not figure out how to delete the post.
Sat, Apr 14, 2007 at 9:13:03 PM | creating Ceiling Plans
coreed
coreed Avatar
4 Stars: 16 Votes
hi mead3724,
it is customary not to try and delete a post, but to post how the problem was solved. even if you solved your own problem.
 best regards,
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
How to load back the Reflected Ceiling Plans into the Project Browser?
Tue, Jun 8, 2004 at 5:41:39 PM
Ceiling Plans
Mon, Dec 19, 2011 at 10:20:40 AM
Floor Plans need to show Ceiling on them in Revit 2011
Thu, Aug 26, 2010 at 12:40:35 PM
To use or not to use . . Floor plan or Ceiling plan . . . for Mech and Lighting
Tue, Sep 13, 2011 at 11:12:09 AM
Room Tags on Ceiling Plans
Fri, Mar 4, 2005 at 9:36:28 AM
Page generation time: 0.9019
