28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Shortening OWSJ's
51 Posts No Rating |
Hello All, Was wondering why I can't shorten the span of some of my OWSJ's (I used the one from the Library "LH Series Bar Joist 24LH11). I framed an opening for the stairs and can't span it to the new beam I placed to pick them up. It gives me the error "Can't make type "LH-Series Bar Joist : 24LH11". I use the pick and drag method in plan to do this. This is frustrating! I even made sure that the beam was at the correct elevation too. Any suggestions?? Thanks!
The way they are created, there are the ends of a fixed length and webbing that is arrayed. Becuase of the fixed end lengths and the fact that the array can't take on a value less than 2 which is derived from the length of the joist the creation will fail under a certin length. You could open the family in the family editor and take a look at what is driving geometry and determine what the minimum length is. I'm not a structural engineer, but those in our ofice who are generally do not use joists for the short spans as they probably can't be fabricated in the real world at that short of length either.
Tom www.reviteer.com http://twitter.com/Reviteer |
Thanks TomDorner, you are right...the joist length was too short for the family to accept. BTW, do you do individual Revit Training via webmeeting or another solution via internet/email? I went to your Blog but I can't find your email address to ask you. (Sorry if I missed it). You are always the person I want to answer my questions because you're usually right and I can understand easily what you post. Thanks!
Thanks for the kind words. My email is listed under my profile, just click on my name and select 'view profile'.I don't do training except for my employer and since we have 500 people in 15 offices I'm kept pretty busy. I try to keep doing a few posts a day on this site, but it is tough to keep up and I have to select only certain posts to answer otherwise this would be a full time job.
Sorry for missing your email address TomDorner, but all I see is your website under your profile. Anyway, I'm sure the people you assist are greatful. Too bad I'm not one of them!
Email is: tom[at]reviteer.com substitute [at] with @ symbol I'm not sure they actually appreciate my effort where I am at though.
OWSJ Family |
Thu, Mar 24, 2005 at 5:04:38 PM
dimension strings |
Thu, Jan 12, 2006 at 7:42:11 AM
Sloping 5/14" metal deck roof to sit on sloping OWSJ structure |
Wed, Dec 3, 2014 at 8:50:16 AM
''Visibility grafics'' and ''create parts'' problem when mak |
Fri, Mar 19, 2021 at 11:45:46 AM
Add ''scale'' on a drawing list, when it is not under ''available fiel |
Thu, Jan 12, 2012 at 8:35:32 AM
