17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> How to create a Sun Pipe family using a Generic model roof based
43 Posts No Rating |
Hi everyone, I am trying to create a Sun pipe using a generic model roof based. The generic roof is flat, so the sun pipe I have create is perpendicular to the roof. The problem started when the roof has a slope 5/12 and the sun pipe shows perpendicular to the slope, instead of going straight down. I have attached a picture of the product and another picture of my generic design. any suggestions to fix this problem?
Matias Santini |
I don't know how you created your family but there is an "always vertical" switch you can set when you build your family.
where is that switch? I new on Revit.
Matias Santini |
Not sure if this switch will work for your family. Edit your family - under the settings pull down, select family category & parameters. The switch is there.
I can't beleive it. It Work!!!! Thanks!
Matias Santini |
roof vent for plumbing |
Mon, Jun 16, 2014 at 1:45:39 PM
Line based generic model family- RAC2008 |
Wed, Apr 22, 2009 at 12:00:15 PM
Sun Tunnel |
Thu, Dec 22, 2011 at 3:52:52 PM
Convert Generic Model floor based Generic -> Generic Model |
Fri, Jun 27, 2008 at 3:02:18 PM
generic model family not cutting in section |
Tue, Jan 11, 2011 at 7:14:50 AM
