Forums >> Revit Systems >> Technical Support >> TITLEBLOCK LINE WEIGHTS
Fri, Apr 13, 2007 at 12:26:22 PM | TITLEBLOCK LINE WEIGHTS
DTCesarz
DTCesarz Avatar
5 Stars: 4 Votes
HI ALL. I'M HAVING SOME TROUBLES MAKING LARGER LINE WEIGHTS IN A TITLEBLOCK.  EVEN IF I GO TO SETTINGS AND PUT IN A NEW LINE WEIGHT, IT DOES NOT UPDATE IN THE PULL DOWN MENU AS IT NORMALLY WOULD WHEN A PROJECT FILE IS OPENED. ANY HELP WOULD BE GREATLY APPRECIATED.
DAN
Fri, Jul 11, 2008 at 11:18:34 AM | TITLEBLOCK LINE WEIGHTS
jtmurph8
I have a question about titleblocks as well.  I am trying to make the text in the title block darker and when I go the the properties of that text and change the line weight from a 1 to a 6 and then reprint the titleblock it looks exactly the same as it did before.  Anyone know what I am doing wrong or how to make the titleblock text darker?  Thanks.
Fri, Jul 11, 2008 at 11:47:48 AM | TITLEBLOCK LINE WEIGHTS
Line weight is not a property of text size .... it was when we used pens.  Text darkness is a property of the text font and text size.
Fri, Jul 11, 2008 at 12:21:07 PM | TITLEBLOCK LINE WEIGHTS
jtmurph8
I am using RomanS text because it is what the client requires, so is there anything else I can do to make it darker besides changing its size? Thanks.
Fri, Jul 11, 2008 at 1:09:01 PM | TITLEBLOCK LINE WEIGHTS
RomanD - same font but darker.
Fri, Jul 11, 2008 at 2:57:30 PM | TITLEBLOCK LINE WEIGHTS
TABEST
4 Stars: 4 Votes
under settings->lineweights create larger line weights.  But this has to be done prior to going into your project file.  If you have already loaded it into your project, then your project's settings override your lineweights, so go into settings->object styles, find the lines under annotations that you are using, and change their weight there...
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:38 AM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:32 PM
A Nice set of Revit Line Weights
Wed, Jun 20, 2007 at 8:47:36 PM
exterior elevations and line weights
Fri, Jul 20, 2007 at 12:06:07 PM
Line weights & detailing 2012
Thu, Jun 6, 2013 at 7:51:24 PM
Page generation time: 0.4019
