Forums >> Revit Building >> Technical Support >> imported DWG visibility
Thu, Apr 12, 2007 at 6:49:10 PM | imported DWG visibility
sattoji
I've imported a surveyor's Autocad drawing into my site plan. I've been able to control visibility of imported layers or the whole survey through the VG dialog box, but the survey now shows up in all plan views. Is there a way to universally control visibility of the imported file/layers? When I select the imported symbol, the "visibility" button in the toolbar is grayed out. I can explode or query it, but no visibility access.
MacBook Pro 2.66 GHz Intel Core i7 running Windows 7 Pro 64-bit on Parallels 6
Thu, Apr 12, 2007 at 10:41:30 PM | imported DWG visibility
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If you only want it to display in one view reimport it with "current view only" checked.
To change the display in multiple views at a time:
Right Click on the view you have setup correctly in the project browser and "Save View Template"
Name it etc.
Then select all the views you want to apply the view template to in the project browser
Right Click and select Apply view template
Select your newly created view template.
HTH.
Regards,
Chris.
Fri, Apr 13, 2007 at 12:26:22 AM | imported DWG visibility
sattoji
Thank you! That takes care of it.
-Satto
Annotations accidentally snapped into linked dwg (Imported categories)
Tue, Jul 9, 2013 at 5:53:11 AM
Imported DWG visibility?
Tue, Aug 7, 2007 at 10:07:42 AM
Imported .dwg File Visibility Settings
Mon, Mar 14, 2011 at 5:29:06 PM
Imported dwg files
Wed, May 10, 2017 at 10:25:29 PM
imported dwg lineweights, linetypes
Fri, Aug 10, 2007 at 9:22:53 AM
Page generation time: 1.3224
