Forums >> Revit Building >> Technical Support >> Floor Trench
Mon, Dec 20, 2004 at 1:05:27 PM | Floor Trench
Joshwilemon1
I am needing to create a trench in a floor slab that cuts through the floor and is visible as stainless steel. Any thoughts. Attached is the profile that might give some clarification of my needs.
Mon, Dec 20, 2004 at 6:07:44 PM | RE: Floor Trench
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Depending on how much detail you want to go to. I would just break the floor where the grate has to go (split the sketch). You could also use an in-place family floor void, if you want to keep it as one sketch. Then create a hosted profile for your grate, add a floor slab edge to one of the edges and position the profile in the appropriate position. You can then associate the stainless steel material to the slab edge.
Sun, Dec 13, 2009 at 3:02:11 AM | Floor Trench
albertiglesia
albertiglesia Avatar
brilliant!!!
"Pleasure in the job puts perfection in the work"
 - Aristotle
Trench Fill
Sat, Jun 29, 2013 at 4:20:48 AM
My Floor Plan Is Not Showing In Some Views
Sat, Apr 25, 2009 at 1:54:41 PM
Trench family for underground utillites
Mon, Nov 10, 2014 at 1:50:19 PM
Ground Floor info. appearing on Second Floor
Thu, Jun 9, 2016 at 2:24:40 PM
floor sketching
Tue, Aug 26, 2008 at 3:35:49 PM
Page generation time: 0.2653
