Forums >> Revit Building >> Technical Support >> callout bubbles and dashed lines
Thu, Apr 12, 2007 at 2:59:22 PM | callout bubbles and dashed lines
pgrimmi
so we have some callout bubbles and the rounded corners don't appear dashed. i know in autocad i would set the plinegen to 1. how do you do this in revit? also can you add text to a column line that repeats? like a gas or water line? thanks again!
Thu, Apr 12, 2007 at 5:02:46 PM | callout bubbles and dashed lines
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You cannot change this setting in revit unfortunately.
With dashed lines revit starts and ends each segment with a dash in order to get around issues where lines used to be longer than they were actually displaying and not showing corners correctly.  Your only workaround would be to change to a finer dashed line so the arc segment is long enough to have a dash at either end with a gap... Sad
HTH.
Regards,
Chris.
Revit 2009: Invisible lines displaying as dashed lines
Sat, Nov 14, 2009 at 11:57:17 AM
11
Detail Callout Bubbles and Dependent Views
Thu, Aug 12, 2010 at 6:51:10 AM
Callout Detail Occurs @ Multiple Locations. Anyway to place detail bubbles...?
Thu, Jan 21, 2010 at 9:09:24 AM
Interior Elevations - 4 callout bubbles combined to single callout bubble?
Wed, Jul 10, 2013 at 5:08:00 PM
Disappearing dashed lines?
Tue, Feb 21, 2017 at 2:16:48 PM
Page generation time: 3.4142
