27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Template
39 Posts No Rating |
Can a template file be a central file already? I am trying to get my new employer's template up and running. One of the summer interns who has some Revit experience created a template file that I would like to use as a base to build on. He saved it as a central file. Can this be used to start a new project/central file and saved to a new central file name without screwing up the central file template?
Yes. I haven't actually tried setting up a template with worksets already enabled?? Our workflow starts without worksets where someone setups the basis of the model and then a project team is involved so worksets are then added. It would be annoying having them already enabled if you ask me. But as long as you do a "save as" and check the option for make this the central file it will have no link back to the template file and won't screw it up. HTH.
Regards,
Chris.
ARCHITECTURAL TEMPLATE VS C0NSTRUCTION TEMPLATE |
Thu, Sep 27, 2007 at 5:19:28 PM
Template Update |
Sat, Jun 25, 2016 at 6:01:29 PM
Template to Project |
Tue, Jul 31, 2018 at 2:25:32 AM
reloading updated template....? |
Tue, Dec 16, 2008 at 12:07:45 PM
Template Version |
Tue, Apr 22, 2014 at 2:02:58 PM
