Forums >> Revit Building >> Technical Support >> Transparent Profile
Fri, Dec 17, 2004 at 5:20:07 PM | Transparent Profile
form
I'm new at this but I created a wall profile for a parapet cap but it appears to be a wire frame or transparent. How do I make it appear solid. Thanks
Fri, Dec 17, 2004 at 6:36:12 PM | RE: Transparent Profile
Osir
An image woudl help understand the problem.
Sun, Dec 19, 2004 at 7:13:08 PM | RE: Transparent Profile
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
1. Check the material the wall (sweep??) is set to. 2. Check you visibility settings. It would help if we had a screenshot and some explanation on what method you've used to create the parapet cap?
Sun, Dec 19, 2004 at 8:33:41 PM | RE: Transparent Profile
ale02
ale02 Avatar
3 Stars: 3 Votes
If everything in your project/ family is in wireframe, properly you can set the whole thing to solid with edge view by simply typing SD. Try to recreate the model again. I wild guess is properly you create your wall profile using void instead of solid because if you create the wall profile using solid, regardless extrude or sweep.. the material setting will still keep back to default material unless you assign it to transparent material. Hope this help!
Life is never easy but nor it should be complex. Just stay simple Smile
Tue, Dec 21, 2004 at 4:01:17 AM | RE: Transparent Profile
form
Thanks for the help everybody - I had the material set on glcurse
Tue, Dec 21, 2004 at 4:01:59 AM | RE: Transparent Profile
form
Thats glass!
Transparent object
Tue, Sep 14, 2010 at 1:18:34 PM
Creating transparent material such as 3FORM
Wed, Aug 26, 2009 at 8:09:06 AM
elevations have gone transparent
Wed, Jun 6, 2012 at 6:02:04 PM
MAKING DEMOLISHED OBJECTS TRANSPARENT
Tue, Mar 12, 2013 at 2:02:34 PM
hosted profile vs. profile
Fri, Jun 5, 2015 at 2:10:31 PM
Page generation time: 0.4478
